Hello all
Come and introduce yourself here
Hello all
Hi Well I've finally got round to registering , I've been a fan of Hexon since the start and after playing the Battle of Hastings game at the Kallistra open day have been revamping my Hexon Terrain for 10mm Zulu wars, 6mm Waterloo and some Tolkien Lord of the rings 10mm Fantasy stuff, If I can work out how to post a pic I will!
cheers Dan
A couple of patchwork field tiles
I've been experimenting with different materials for my fields, towels etc.
Heres a wheat field tile for the waterloo board, it will be 6ft x 16ft when finished
Heres two together, I've also made some full water tiles to make the river wider if needed
Heres a tile I added some milliput banks to, making river sections
Re: Hello all
Hi Dan, welcome to the forum. :D
It's good to see the modelling you have been working on, it's looking really great. Looking forward to seeing the full layouts! Thanks for sharing the photos :D
Re: Hello all
Cheers Sally, I just need a space big enough to lay it all out!!!
heres a few more things I've been working on
Waterloo Farm
Waterloo Farm
The church mounted on the forest templates, I've based all my buildings on these, perfect!
A little retouch and spray on the road sections
A Stream source, re painted the stream a muddy brown
An escarpment with some added detailing
curlerman
Re: Hello all
Post by curlerman »
oh those really are very nice. I use modular cork boards and have never really been tempted by hex terrain. Your tiles really are excellent though and the way you have personalised them is VERY attractive!
Winning is not a priority for gamers but losing is a definite no-no
web:- http://www.angelfire.com/games4/bobsgam ... urlers.htm
blog :- http://flownlegions.blogspot.com.es/
von Klinkerhoffen
Re: Hello all
Post by von Klinkerhoffen »
Curlerman you should treat yourself to some hex terrain it's good stuff!
Chopperboydan, those are excellent. I particulalrly like the wheat fields; this has been cut from door matting? Did you have any problems cutting it to fit the hex terrain tile?
von Klinkerhoffen
Re: Hello all
Cheers chaps,
no the wheat field was cut from a rubber backed terrain mat from a railway modellers product, can't remember what its called I will try and find out, it was around £20 and I had enough to cover 8 full tiles, I have used door mats too but haven't stuck them down so I can lift them off when troops move into that hex, very simple to do using a one hex template and a craft knife, I will post some pics soon.
von Klinkerhoffen
Re: Hello all
Will be interested to know what the products called.
von Klinkerhoffen
Re: Hello all
Hi again, the wheatfield is from BUSCH - Cornfield/wild grass mat, 80cm x 80cm around £20. A lot easier and a better look than flock
cheers dan
von Klinkerhoffen
Re: Hello all
Thanks for that.
von Klinkerhoffen
Re: Hello all
no worries, heres a few more pics of my Hexon stuff
tell me when you've seen enough :D
another Belgium farm
more buildings!
more buildings!
more stream sections
perfect for the Zulu board
more escarpments
more escarpments
